88BB8B
- 179
- 18
- Oct 14, 2016
Coldstream,
BC_Canada
I did some serching, but coildn't quite find what I was looking for.
My 1997 Talon TSI has the supporting mods to turn the boost up just a bit (was running 15psi when I very first got it) blew up the shitty trans that was in it, and it sat for a while, after getting the new trans in, it was boosting to only 13-14 pair, which I wasn't ecstatic about, but at least it's not very harmful. As I've driven boost slowly went up, until last night it was boosting perfectly to 15 pain, then holding. This morning, I find particularly in second gear, it's boosting to 17, and kissing 18psi. But in 3rd or higher it only boostzs to 15.
I have an HKS electronic boost controller, and stock wastegate and everything. I'm wondering if anybody can tell my why it might be overboosting, furthermore, is 17psi on the stock fuel system, stock T28, and 3" exhaust definitely harmful. Would it be obvious to me driving if it were knocking?
My wastegate actuator is only bolted on to the turbo with one bolt, could it just be pivoting on the bolt, and thereby causing the boost pressure to change?
