1kick
5+ Year Contributor
- 84
- 17
- Mar 27, 2018
Santa fe,
New_Mexico
hello i need help trying to understand what could be going on with my 97 eclipse gst i have some live data in the attached pdf file from a scanner it seems like all 4 injectors are stuck open it backfires at idle will rev sometimes its missing checked compression cold it had 100psi in all 4 140psi wet timing marks line up no dtc
i have also tested the wires from the injectors to the resistor box and to the ecu no shorts im stuck and need help please
