Throttle Body Rebuild Kit
Can you send me a quote for a 1G Turbo Kit with Mil Spec seals, tool, and extra set of seals in case I screw up the first time.
Thanks
Do u have a for rebuild kit for a 97 gst 7 bolt, normal seals
My brother and I have been doing throttle body rebuilds for a few years now, but I know there's a lot of people out there who like to fix things themselves. So we are now offering a throttle body rebuild kit! This kit includes all the parts needed to rebuild a throttle body and eliminate any of those pesky shaft seal leaks that we all love so much. It eliminates the oh-so-common stripped screws by replacing the FIAV ones with allen head pieces and replacing the shaft screws with new ones.
Kit works with:
'91-'94 Non-turbo throttle body
'91-'99 turbo throttle body
Evo 3 throttle body
Kit contents:
(1) OEM FIAV gasket
(5) stainless steel allen head FIAV screws (with stainless steel lock washers)
(1) OEM BISS screw
(1) OEM BISS o-ring
(1) OEM ISC o-ring
(2) stainless steel allen head ISC screws (with stainless steel lock washers)
(2) stainless steel allen head TPS screws (with stainless steel lock and flat washers)
(1) stainless steel lock washer for shaft
(1) stainless steel jam nut for shaft
(2) stainless steel shaft screws
(2) shaft seals
Notes:
All hardware is 18-8 stainless steel.
FIAV screws will work with or without FIAV bypass plate.
ISC screws will work with black or tan ISC.
Kit options:
1. Normal shaft seals (have been tested at 30psi with no issues) - $55 shipped
2. Mil.Spec shaft seals - $70 shipped CURRENTLY OUT OF STOCK
*Notes around mil.spec seals - http://www.dsmtuners.com/forums/bolt-tech/436875-mil-spec-throttle-body-shaft-seals-dont-fit.html
Extras! *NEW*
We now have shaft seal install tools available for sale. These will work with all seals, but are extremely helpful for the mil.spec seals. These will drive the seal in straight, which is key to preventing damage to the seal.
$15 + shipping
Or if ordering a mil.spec seal kit, $15 as shipping is already included in the seal kit price.
Kit and seal pictures:
Kit works with:
Evo 3 throttle body
Kit contents:
(1) OEM FIAV gasket
(1) OEM BISS screw
(1) OEM BISS o-ring
(1) OEM ISC o-ring
(2) shaft seals
Notes:
Kit options:
Extras! *NEW*
$15 + shipping
How can I get one
@snowborder714
Private Message snowborder714 and let him know what you need. He should get a notice since I put a @ symbol in front of his screen name.
Marty
@snowborder714
Looking for a milspec rebuild kit for an 2g gst and International shiping. Message me, please.
