Chumpaumpalumpa
- 1,554
- 303
- Jun 16, 2014
La Habra,
California
Hello I'm new to tuning V3 so for now I've just been tuning it like you would in V2 using the sliders. Yes I will be using the tables when I resolve this issue. Basically its been leaning itself out at around 1900Hz and only getting worse and worse. Ive tuned around it so that it can progress to the point where something might be obviously wrong. Around that frequency at 30 psi the car misfires now as well. That symptom is new. It gets worse as the air gets colder. I have new BR7ES plugs in the car. NGK plug wires that are a year old and the car is on E85. If I turn the boost down at all it doesn't miss. The car leaning itself out consistently and only in one RPM range is very weird to me. Compression was 165 across the board. Heres 2 logs I took with the issue happening. I let out right after it happened but if I keep in it it clears up. Happens around 6300RPM and 1900Hz-2100Hz or around there.
Thanks to all who chime in!
