4gfun
Supporting VIP
- 2,009
- 55
- Dec 10, 2007
Ask Me,
Virginia
So my last post was regarding changing tires with my harbor freight manual tire changer. Great advice there and things are going well.
Well I used to have a "buddy" with a dynamic wheel balancer who would put lead hammer weights on my aluminum wheels instead of stick on weights. He moved on and years later I heard that was a no-no. I am not sure if that reasoning is true and if so if it's just for cosmetics reasons or....
because these weights tend to cause leaks around the aluminum wheel bead.
This is what is happening on several of the rim tire combos he did a few years later. I develop a slow leak and put the tire/rim in a dunk tank. Sure enough, it is always in the same spot. It doesn't matter what vehicle's rim/tire set it is either.
So...I have had fantastic luck with my harbor freight bubble balancer and stick on weights. I always get it right and never get shaking at any speed. I am hooked. I usually use the technique of putting the stick on weights in the middle of the wheel which is supposed to negate dynamic imbalance. Not sure what the theory is but I don't care as long as it works.
My question is this. Some of the wheels/tires he did are not yet leaking in that spot and yet the balance on those wheels/tires is beginning to degrade.
Can I leave those lead weights on there and add stick on weights after identifying a correct balance on the bubble balancer? I only ask because:
1) I don't want to disrupt the bead by removing the old hammered on weights which is SURE to happen.
2) I don't want to dismount the tire manually when I can avoid it. I am getting better at using my mojo tire lever each time I use it, but the process is DEFINITELY intrusive and want to avoid dismounting the tire when I can.
So, can I expect to be able to balance the rim/tire with an existing hammered on lead weight or do they need to come off? It's one of those things that I don't want to *try* 4 times just to find out that it won't work.
Thanks!
Thanks!
