thakingcb7
- 198
- 6
- Feb 8, 2015
Lewistown,
Pennsylvania
So I just replaced my clutch (2600) last week. Put a new pivot ball on in hopes of not having to shim it. When i tried to shift into ANY gear while the engine was running i had nothing. Tore it all apart Saturday and shimmed the ball and put it all back together... Still no shifting while engine is running. Both master and slave are new within the last year and neither one is leaking. I checked the pedal assembly for wear and it's also tight. I know there's no air in the line either because I didn't unhook it and the slave moves as soon as pressure is applied to the pedal. The only thing I have left to try is adjusting the master (per the jacks video) which I'll try tonight but when I was checking it out last night I had noticed that the rod is threaded flush with the pedal.
All this is on a 90 tsi. After the adjusting the master I have nothing else I can think of the check. Maybe I'm missing something? Any and all pointers are very much appreciated because I'm burnt out on this project at this point.
