Galipso
Supporting Member
- 223
- 17
- Aug 23, 2011
Tampa,
Florida
A while back maybe a year ago, my upper radiator hose made a small split right where it connects to the radiator just before the clamp. It sprayed coolant everywhere and almost overheated. It was close enough to the clamp that i was able to just cut an inch off the hose and pull it tighter to the radiator and clamp it back down, problem solved right?... Well, it just happened AGAIN last night.
Is there a degradation problem with the stock rubber hose? Do i have too much pressure being built up?
I bought a rubber replacement but im wondering if silicone might actually be better?
