For Sale 1997 GSX Eclipse 10.000
4g63tmotors
3
Jul 18, 2017
Fort Madison, Iowa
I am putting my GSX up for sale/ trade, i have no need to sell so price is pretty firm unless you've got a decent (Awd) vehicle for trade and some cash, i am interested in the newer AWD lancers and subarus that are non turbo
Car has always been stored for winter, has all power accessories, moon roof, tinted windows, a/c, carbon fiber hood, 7" touch screen stereo with 2 subs and an amp. Car makes 420 Hp or 353hp/325 ft lbs of torque on the dyno. I beleive it maxes out at 28-30psi for the turbo. Body has 151k on it but still in great condition, motor has less than 16k miles on it, it was built by http://strictlyperformance.parts/ , they specialize in high performance cars such as GTRs, DSMs, and Evos. No joy rides and serious request only please. Engine and transmission have over 15k in it not even including all the other parts. When the new clutch was put in all couplings had dry spray put on them and bolts got thread locker also, turbo downpipe has all new clamps. Also the transmission/ transfer case was flushed.
K&N air filter, FP intake, SIM T3 Custom manifold, Trial MV-S 38mm wastegate, FMIC, Greddy BOV, UPIC piping, Aeromotive FPR, Hallman pro MBC, Holset HX35 turbo, BEP T3 .70 ar turbine housing, 1000cc injectors, Walboro 450 pump, pump rewire, full 3" exhaust, evo oil filter housing, mishimoto radiator/ fans, Thermal Zero turbo blanket, dual oil catch can setup, exterior oil cooler with thermostat and fan. Also the car has 2 step launch control and runs on 93 octane, also you can get a retune for it to run on E85.
Mods-EMS & Logging
ECMlink V3 full version, innovate MTX;L wideband, speed density conversion.
Mods-Engine
SIM stage 2 short block. Delta 272 cams, Manley springs, mild port job, 3G lifters, Manley forged pistons and rods, balance shaft delete, external oil cooler and thermostat.
Mods- Drivetrain
TRE stage 3 rebuild with 4/spider gear setup, act 2600 installed 7/12/17 . Prothane motor mounts, Exedy clutch master and slave cylinder, STM stainless clutch line w proportioning valve removed.
Mod- Handling
eiback pro springs, Kyb struts, EVO brakes front and back, slotted and dimpled rotors, 15mm wheel spacers to clear the brembos.
Just wanted to add it also has a new master & slave cylinder. also recent oil change. Car includes DSM link which is roughly $500 itself and I'd be willing to go down to $9000.
