95eclipser
- 2,003
- 309
- Feb 3, 2006
Manassas,
Virginia
Hey Guys, My build is now complete!! but I have hit a bump trying to get it to start and cannot figure it out. I need help diagnosing why my car will not turn over. The starter just "CLICKS"
At first i thought the starter was bad so I replaced it. But I soon realized that the new unit is doing the same thing as the old starter did. I have a made a quick video of what the car is doing. I am manually connecting power to the starter with the yellow wire
thanks ahead of time,
Drew
IMG_0231[1].MOV - YouTube
<iframe width="560" height="315" src="http://www.youtube.com/embed/zUH5N-zDFWo" frameborder="0" allowfullscreen></iframe>
I found this VVVV
Drew
Drew
I found this VVVV
I have a 2g starter plate. Could the starter be making contact with the plate? or hitting the flywheel?Youll need to put on your 2nd gen starter bracket, but before you do this youll have to modify it. The bolt hole on the bottom will not line-up and youll have to grind a hole up and towards the front of the engine. Also the transfercase (AWD) will need more room to fit on. Youll need to trim where that bottom bolt was, trim it almost back to the original hole and youll need to pull the metal out thats above and to the back of the engine. Youll see this all when you try to put on the transfercase and it wont fit on. No worries though, its not that hard to grind and fit it when it is on the car.
Drew
