Drag Race Build My 2g dsm second build, this ones going smoother
Nice build!
I am sure you have checked, but just in case make sure you check/tighten those cam gear adjustment bolts.
WELLL MY PUMP SHOWED UP TODAY!!! TIME TO FUEL THIS BEAST!
Meh, the whole setup just looks cheaply done and just filled with turd parts. Haha, jk the engine looks badass :). Don't get happy now, you still gotta a lot of work to do. What was the turbo you were going with?
i found a t4 hot side for my turbo, i posted the wrong specs before, the specs i posted was for a much larger turbo then what i had, my current specs are ... with a t4 housing! and yes the journey is close but i still hae a ways togo!
Compressor Specs:
- 63.5mm compressor wheel inducer 66lbs/min
- 5" Hose inlet 4.21 V Band Outlet Compressor Cover
Turbine Specs:
- 74.3mm turbine wheel exducer
- 1.10 A/R Twin Scroll T6 Turbine Housing 5.75 Marmon Outlet
pick up my 10 gallon fuel cell today, and also got 15 feet of -10an fuel line, im gonna use the push on fittings with lock clamp. thhe hose is 1000psi burst pressure, the minimum on the pump
well i finally did it guys!!! got that dam fuel cell in, i made a frame and also made the straps my self, check it out, and yea one more thing i put the motor in!!!!
i just gotta paint it and the frame for the cell is all done
fuel cell
engine
hey all!!!!! ive put the dsm on hold for a little but im back at it!!!! im paying off an aem v2 ecu for the car right now, cant wait =)!! im also looking at a divided t4 manifold as well for the build!!! i think im just gonna get him up and running for now with a 500-600hp tune... then work on drive shaft... welding diffs... transfer case... ect... let me know what you want me to do and what you wanna see... please all question and options welcome!!!! i do need them!!!
welp its been a while!! so heres the scoop! im gathering oem bolt on parts just to get it started! hopfully this weekend or the following week it will run! this is only to cycle the motor. then i will be getting the parts i need to make her fast!
i sold the aem v2 the other day. i want to have the car be street-able. so i ordered a ecmlink v3 full from a current member on here.
its been a long road and its time to start paving that road so i have do racecar stuff on it :D
items ordered this week to get running
1g stock intake manifold
1g stock exhaust manifold
ebay fuel pressure regulator
stock 450cc injectors
ecmlink v3
gm style speed denisty kit
rear oem 3 piece tail lights
need to run---- if you have used and cheap please let me know!!!! items must work
inline cheap fuel pump
tps
iacv
thats all i think i have left to get :idontknow: but once i start putting these parts on ill make an updated WTB list
SHOW SUPPORT! THE FLASH IS GOING TO LIVE!!!!!!
