cowmilker69
- 2
- Mar 13, 2016
Mississauga,
ON_Canada
So installing an HID kit should be a walk in the park right? Well that was most definitely not the case when I tried installing my HID kit. I read and watched how to install them and I will say it looks pretty easy. When I went about installing mine I came across an issue. The plug that connects back to the stock harness, does not fit at all. Doesn't even look like they're suppose to connect. I attached two pictures for clarity. The plug on the right is from the HID kit and the one on the left is my stock harness.
Any help would be greatly appreciated. I've tried two different HID kits from two different companies and had the same issue with both. I cannot figure out what the problem is.
