twicks69
Supporting Vendor
- 4,204
- 1,665
- Mar 12, 2004
Milwaukee,
Wisconsin
***PROMOTIONAL PRE-ORDER PRICING***
Sonnax is manufacturing a Heavy Duty Forged Steel slip yoke made for DSM AWD customers that have an upgraded 300m transfer case and are tired of replacing their twisted Spicer brand cast slip yoke.
The order was placed 05/26/2017. The yokes should arrive around September 2017 from Sonnax.
The promotional pre-order cost is $185.00 + shipping costs - you get it on the website at:
https://www.tmzperformance.com/shop...upgraded-dsm-transfer-cases-with-300m-shafts/
If you want to do it directly through Paypal instead of the website, you can send payment to [email protected] for $196.20 including fees, or $190.00 if you are sending it as a gift.
Once received, all pre-orders will receive their parts first, and then the price will be increasing to $215.00 + shipping costs.
This slip yoke application is for the larger 25-spline Ford slip yoke normally provided with upgraded 300m transfer cases from me, or Liberty Gear, or Boostin Performance, TRE, etc. The cast version Spicer slip yoke is also found on the Heavy Duty DSS 3.5" Aluminum or Carbon Fiber driveshaft applications for 1G/2G DSM's.
The standard Dana / Spicer 2-3-8431X is notorious for twisting on launches resulting in regular replacement by the user, or it becomes a binding problem on the transfer case output shaft, resulting in other damages that can occur.
This Heavy Duty Forged Steel slip yoke remedies that problem with significantly better material being used for manufacturing, as well as better overall machining, excellent circlip fitment and beefier material around the U-Joint bosses.
The slip yoke has a black hard coating on all surfaces for excellent longevity, resistance to oxidation and better wear protection. It is a DIRECT REPLACEMENT for the Dana / Spicer 2-3-8431X slip yoke, and is a simple 5-minute installation on the driveshaft. This also uses 1310 Series U-Joints, which is the same as the DSS HD 3.5" driveshafts.
This slip yoke WILL NOT FIT users with stock driveshafts or stock transfer cases. It is specifically for users with 300m upgraded transfer cases using upgraded driveshafts with 25-spline slip yokes and 1310 U-joints.
DETAILS / TERMS:
This is a non-refundable pre-order. You are paying up-front for a discounted price and your place on the batch order of 50. Once they are sold out, they are all gone. I will likely only make one order for these.
It is a 3-4-month process to have them manufactured based on Sonnax's current job timeline from the order date of 05/26/2017.
Full payment up front is required to get on the list. PayPal is preferred. I also accept credit card, verified personal checks, money orders, and cashiers checks.
I have provided several images of the slip yoke as well as the installed product on Mike Wohler's 2G DSM carbon driveshaft for reference.
I will update the pre-order purchase list very regularly on all post locations.
This Group Buy is also on my Facebook TMZ Performance Page, as well as ECMLink Forums for greater visibility.
More images are in the thumbnails below.
DETAILS / TERMS:
18156388_10211898112715803_3935634030668975362_o (800x481).jpg71.7 KB · Views: 360
18156480_10211898112275792_7421895109110258534_o (481x800).jpg65.7 KB · Views: 377
18192537_10211898110515748_8366545592662014210_o (800x481).jpg67.5 KB · Views: 402
