boostdawd
Supporting Member
- 1,430
- 320
- Apr 6, 2010
phoenix,
Arizona
Thanks for the heads up. I'm going to be switching the vaccum lines to 3an or 4an in the future. Pricey but better than replacing parts or risking something failing.
I also ran out of e85, I went through 10 gallons like it's nothing.
I just got 10 gallons for 2.19/gal to replenish my "home" refueling station . I know your gonna love runnin it. My setup allows me 21* timing up to 8500 but still needs tuning work. On close to 40 lbs. Good job man, keep it up and your results! My latest fuel % was 68% but the car still works with it25 gallons of e85 for 70 bucks vs 189 for 10 gallons of c16 ... hmmmm?
My flex fuel sensor is registering 68-69%, my engine likes to be in the low to mid 11's for afr.....I took it out on 20-21 lbs and ripped it.... cars estimating around 370-400hp which falls in line with the airflow I'm making. Car feels like it needs more air.....ie more boost.... way more boost. I'm just worried about blowing my headgasket. After blowing the last two.... I lost faith. Hopefully I'll have better luck with this mlsI just got 10 gallons for 2.19/gal to replenish my "home" refueling station . I know your gonna love runnin it. My setup allows me 21* timing up to 8500 but still needs tuning work. On close to 40 lbs. Good job man, keep it up and your results! My latest fuel % was 68% but the car still works with it
I understand creeping up on your timing which is the right thing to do. It will probably like a little more. I'm on 10:1 CR.
Your running 40psi of boost? At the compression? What injectors and pump Are u runningOnly for reference, I have 10:1, Cometic MLS Copper Coated with L19's torqued to 110. Accidentally saw 44 lbs for a bit i one log so turned it back down to just under 40. Now working on making it work all the way to 8500. Have seen 8940 but never 9000 yet. HX 40 T3 .70 Vband 3" and a cutout.
If you don't mind, At 40psi what dc are your 1650s at? I'm wondering wether or not the 1650's enough for me thanks.340 Aeromotive and 1650 FIC's. It runs 21* up top, so you see, every setup works out differerent. But I think you still have more potential.
What settings are your running for the injectors? im at like -67 global andI am in the high 80's. I have a set of 1800's, brand new, in case it is wanting more fuel but so far so good.
Whats strange is that the global calculator is telling me to run -57, what actually works the best is -67 , my deadtime is like 228 give or take. At 20 psi this keeps me mid 11's for afrI am in the high 80's. I have a set of 1800's, brand new, in case it is wanting more fuel but so far so good.
What ive been doing is , say i turn up the boost, i do a pull wot and watch the afrs, if the afrs collectively are rich for example I add to the global. So ill go from -67 to -67.5 and go for another pull. If the afrs are better and really close. I go in to the sd table and add or subtract airflow until the predicted afr and actual line up. is this the way it should be done?The calculator and my injectors didn't really agree either. With E85 always for the last 2 years my Low Z 1650's (yeh low z) are at -51.2 with DT at 330 when the calculator says -59 and I still play with DT and have had it in high 400's. Now I admit that is going to skew numbers on DC and many other small things, but the fact is the CAR likes it. I have sat in it when it wouldn't even start and played with it until it did then adjusted from there. Its a beast but I am not a pro tuner I just play with my car. Its a lot easier to sit in it and adjust things and see how it feels than it is to go with set figures. I still need help myself, I just haven't asked yet I hope this helps at least a little.
Ok so looking at my log in the sd table in the 4500 column 31.2 to 40.4 is over 100% this mean I need to add fuel ie, lower my global exp. 67.1 to 66.9 etcYou'll know when global fuel is right when your SD table reads right at 100% at peak VE. If it's more or less, your global fuel needs to be adjusted.
If your peak VE is over 100% in your SD table, you need to add fuel via global, if it's under 100%, you need to subtract fuel via global.
If it's right at 100%, then tweak the SD table until your WBO2 lines up perfectly.
