doubleclutch
- 830
- 175
- Jun 26, 2009
Canton,
Michigan
Found an interesting problem. The motor on the upper driver's side likes to loosen up it's bolts over time. I actually had to get new studs due to the old ones being destroyed by the mount rubbing against them. This isn't the first time I have heard of that joint failing. The studs actually came out of the mounting bracket about 4 turns and were loose enought o wiggle.
Two things:
1) Is this failure prevalent enough to warrant adding a "tighten motor mount studs" to the recommended maintenance?
2) I bought new studs from stm. They are supposed to be for the 2g mount on that side. Attached are the old part and the new part side by side. They definitely are not the same. Most noticeable is the lack of "his" on the new part and the length difference. The length doesn't seem to matter, but the mount is shaped to utilize the "hip" shape. Is that going to be an issue? Did I get the wrong part?
Two things:
