twicks69
Supporting Vendor
- 4,203
- 1,662
- Mar 12, 2004
Milwaukee,
Wisconsin
Hello all my fellow DSM'ers! We found a batch of brand new Evo 3 input shafts with matching Evo 3 1st gears, and Evo 3 5th gearsets and they are ready to ship out to customers that are looking for these rare discontinued parts!
We currently have 10x Evo 3 Input shafts and Evo 3 1st gears in stock.
The input shaft and 1st gear are already shot peened for additional strength and durability. This 1st gear is a 2.751 ratio and is 12% taller than the stock DSM 1st gear. 1st gear synchro used is the shallow-style MD742419 for use with double springs. This set is interchangeable with 1990-1999 AWD W5M33 Mitsubishi transmissions found in the DSM (Eclipse/Talon/Laser) along with the Evo 2/3 and Galant VR-4. It does not fit in FWD F5M33 transmissions.
If you need additional installation components, such as end shaft bearings, shaft nuts, hub and sliders, springs, keys, synchros, etc. just let us know and those components can be ordered. Just send an email to [email protected] regarding the parts needed.
You can purchase the Evo 3 input shaft and 1st gear here - https://www.tmzperformance.com/shop...et-input-shaft-and-1st-gear-dsm-evo-2-3-gvr4/
We currently have 6x Evo 3 5th gearsets (both input and intermediate gears) in stock.
These are pretty much the last known brand new OEM Mitsubishi Evo 3 5th gearsets left in existence. The gearest is a 0.617 ratio and is 10% taller than the stock DSM 5th gear. They are not available new anywhere else and were very hard for us to track down from Japan. Both gears are discontinued items from Mitsubishi, aka obsolete. 5th gear synchro used is the late-style MD745892. This set is interchangeable with 1991.6-1999 AWD W5M33 Mitsubishi transmissions that use the late-style 5th/reverse hub and slider assembly with steel shift fork. It does not fit in 1990 style 5th/reverse transmissions without significant modification and additional parts. This gearset will also fit 92-99 FWD F5M33 transmissions and is 20% taller than the stock 5th gear.
You can purchase the Evo 3 5th gearset here - https://www.tmzperformance.com/shop...nput-and-intermediate-gears-dsm-evo-1-3-gvr4/
Thank you all for the continued support and business! This community we share here is the reason why we continue to build these transmissions!
Thanks,
Tim Zimmer
TMZ Performance
-twicks69
These are all special order / discontinued items, there are no returns or warranty associated with them.
Thanks,
Tim Zimmer
TMZ Performance
-twicks69
