1g engine flushing ?
Christian Villano
Feb 18, 2017
Weeki Wachee, Florida
Hi my name is Christian Im new to the the site & I need some guidance on my build. I bought a 1992 eagle talon tsi, owner before me only ever ran hose water as coolant never used anti freeze. So the system is a little rusty, I've flushed with water but there is still rust through out the whole system
And was wanting to know can I use a system flush on it ? So I was going to run the flush with water and really get the system clean. The turbo is coolant and oil cooled so idk if I can or not some help would be much appreciated Thank you
If it has lived on water alone for any decent period of time you can bet there is a heavy layer of scale that a style bought coolant system flush won't even begin to budge.
CLR works and also a chemical called evapo rust ^^ in a 5 gallon bucket. It's reusable until it turns black I think and works like a charm. Hope this helps.
which one did you use for the ones in the pic's..CLR? OR EVAPO RUST?
