91talonts1
- 715
- 278
- Dec 29, 2008
Spencer,
North_Carolina
-6an lines should be plenty. You have to have an aftermarket sensor to log fuel pressure. If you have a gauge on your regulator you can set a go pro up under the hood to record it as you make a pull.
I assume you've rewired your pump and it's got plenty of volts at wot?
