TheFlashDSM
Supporting Member
- 1,082
- 312
- Feb 18, 2010
stony brook,
New_York
this is my current build http://www.dsmtuners.com/threads/my-2g-dsm-second-build-this-ones-going-smoother.499369/
i didnt have money to go buy a 2k turbo for my build but im willing to upgrade this one to make it work PLEASE HELP I CANT FIND MUCH ON UPGRADING THIS TURBO!
my goal is to run 8's and get close to 1000hp with nitrous to help spool!
the turbo i bough brand new is a bw s400 t6 part number 169012 https://www.amazon.com/Borg-Warner-169012-Turbocharger-S400/dp/B0156KP3QO
specs -
1. should i leave the t6 or get a t4 for the exhaust? AND WHY?
2. should i upgrade to a billet wheel like this one, or what do you prefer i get AND WHY? http://www.spturboost.com/products/borg-warner-s400-s475-turbo-spx-billet-compressor-wheel
3. can i get a ball bearing conversion done to this turbo, and if so from who in the USA does it?
4. WILL IT WORK FOR MY BUILD!?
PLEASE POST OTHER THREADS SO I CAN READ THEM IF YOU KNOW OF ANY, AND PLEASE NO HATE ON THIS THREAD! THERE IS NO OTHER THREAD LIKE THIS SO IT CAN BE HELPFUL TO OTHERS LOOKING TO DO THE SAME.
EXPERIENCED ANSWERS ONLY,
THANKS - RICH
specs -
- Compressor Wheel Inducer Diameter (mm): 75mm
- Compressor Wheel Inducer Diameter (in): 2.94
- Compressor Wheel Outer Diameter (in): 3.94
- Turbine Wheel Outer Diameter (mm): 96mm
- Turbine Wheel Outer Diameter (in): 3.77
- Turbine Wheel Exducer (mm): 88mm
- Turbine Wheel Exducer (in): 3.47
- Turbine A/R: 1.32
- Turbine Inlet Style: T6
- Scroll Type: Twin
THANKS - RICH
