Golfer
- 67
- 6
- Sep 21, 2009
E,
Texas
Let me start off by saying this is a 7 bolt timing belt job on an Evolution 2 (ce9a) block. I purchased all new oem dsm 7 bolt parts (timing belt, pulleys, auto tensioner, front case, etc) the only thing that remains from the evo motor is the tensioner arm and the engine mount (the only two things I could imagine causing a problem). So at first I tried tensioning the pulley per the manual, 2-3ft lbs or whatever it asks for, but every time Id go to tighten pulley bolt the pulley would move and mess up the tension. I tried fighting the resistance and broke the pin on the jay racing tensioning tool. Plan B was to use the crow bar trick and make sure the grenade pin moves freely after 15 min. Well that works, but I am not passing the drill bit test. When measured properly (drill bit parallel to surface of auto tensioner) its about 0.125" I can however get a 5/32" (0.156) drill bit in there but its at an angle (as seen in attached photo)
Does anyone know what is going on here? Should I buy a new tensioner arm? Am I over thinking this and should just leave it at 0.125 as long as the pin fits in there?
Thanks
Thanks
