import2gtuner
- 38
- 0
- May 9, 2014
Toronto,
ON_Canada
Hello everyone, I have a 1998 GST that I acquired to replace my 96 that I lost to rust. I haven't been able to thoroughly enjoy it because the RPM gauge doesn't work and the MPH gauge lags and reads between 15-20MPH off all the time (when it wants to work.) The fuel, temp, and boost gauge all work fine.
I've tried switching the gauge cluster with 2 different working clusters, changed the VSS, still doing the same thing. I hooked up a diagnostic and it was reading RPM's from the ECU just fine (although it lagged.) So I'm not sure if the ECU could be on the way out or if it's a matter of tracing down wires.
Any input would be greatly appreciated, thank you.
