2G Hard vacuum line
TrevoREX
106
12
Sep 2, 2013
Kalamazoo, Michigan
Not sure if this is the right section for this but I figure I'll give it a shot. I've tried some searching here and on google. Has anyone done anything with steel tube for vacuum lines. I only ask because I have the bender and leftover line of a good i.d.. Pics would be great. Thanks in advance.
just do AN lines
just do AN lines
As much as it would be nice, i wouldn't want to spend the money on AN lines, and the hardline would look a bit cooler IMO. kind of steampunk-ish.
AN lines just get too out of hand, just doing my oil supply manifold I spent almost $175, so its a little off-putting.
Sounds like a pain in the but. It might be harder to work on the car too because you would be able to just swipe the line out the way for a minute.
yeah that would be a factory look, I would do that if i had the time
Placement of the lines would have to be taken into consideration for sure.
I'm likin the feedback guys, keep it coming. Again some pics would be great.
plus you would have the confidence in knowing there isn't a small crack or pinhole on the back of a rubber vacuum line where you cant see it, causing whatever issues you are trying to troubleshoot
