1990TSIAWDTALON
Moderator
- 11,540
- 8,207
- Nov 14, 2013
Independence,
Kansas
I still will never understand the "get stuff rated for ethanol" thing. Fuel has had 10% ethanol in it since I can remember. I would think if it were going to ruin something in your fuel system then everyone running gasoline would be seeing fuel system failures.
It is because E85 is so strong with ethanol (which attracts moisture) it can rust up the insides of fuel injectors so bad that they are not useable anymore. You will notice that E85 users usually run "gas" through their fuel system if they are not going to be running the car for a month or longer. My son had a set of 2150's that had E85 sit in them for a year and they had to be completely rebuilt by FIC for that very reason and that is the information that they told him.
