Darksurfr
- 31
- 2
- Aug 29, 2005
Old Bridge,
New_Jersey
I know people are going to laugh at me and say just remove it but lets just start out knowing I like Cruise and I use it often
Now that that is said I am wondering if anyone knows if all cars came pre-wired for cruise control even if the car doesn't have cruise. My 90 has the connector under the hood where the 90-91 cruise vacuum setup goes but After pulling the dash out (mostly) I can't seem to find connector C-01 which is what connects to the cruise control module or ECU if you will.
Does anyone have any knowledge of where this might be? It should be under the driver's side of the dash above the fuse panel but I see no connector or something that looks like it would connect to the cruise ECU I have which might be out of a 92+ car ? If someone has a picture of what the ECU for a 90-91 car would be that would be excellent as well. I have both the 90-91 vacuum setup and the 92+ that mounts on the firewall because it is much cleaner and will not interfere with my IC piping.
Thanks in advance
Scott
Thanks in advance
Scott
