- Thread starter
- #26
99gst_racer
Moderator
- 11,982
- 1,556
- Apr 5, 2003
Coloma,
Michigan
There is not a universal perfect amount for everyone here. Ideally, you'd want to plot your arm angles at your given ride height and figure out how much inboard pick-up raise would be an improvement for your roll centers and instant center. But I believe there's only room for about 1/2" raise (which is pretty much all there is room for on LCA's too), which is better than nothing at all.1.) What is the min. amount (inches) the inner pick-up points need to raised in order to for new control arms to be effective?
One of the primary benefits on these arms would be to adjust camber and caster. As it stands, some of the other options on the market have issues with the design. The Megans and SPC's have an adjustable balljoint and there have been reports that it doesn't stay put under heavy loads. This is why I wanted to adjust balljoint location by directing it with inboard adjustments.-It would be a real shame to put all this work in only to determine after the fact, that the major benefit is steering feel due of the switch to heims and not see significant increase in corner speeds.
I wouldn't be able to answer this until I start or finish the first set. A lot of this will depend on which balljoint I end up using. Either way, any wear components will be readily available.2.) What off the shelf components are available (A&A Manufacturing, Speedwaymotors, etc...) that would make this easier to manufacture and service?
I appreciate the brainstorming. I don't think there's anything to gain by such a modification. I'd be willing to bet most guys wouldn't be interested in permanently modifying their car, as apposed to using a bolt-on affair that functions the same way.3.) Should we consider abandoning the factory inboard mounting location in favor of a bolted/welded in bracket, so that a more traditional upper A arm style can be used?
-This is bit of a stretch but when brainstorming there are no bad ideas, right?
* Camber adjustability4.) What are the suspension settings this kit will help users achieve?
-I think this is one of the most important points to establish as
* Caster adjustability
* A replaceable balljoint
* Sphericals instead of bushings, so no more bushing deflection.
* And I'm unsure of any weight savings at this point.
