trapdad
- 41
- 0
- Mar 29, 2016
Lapeer,
Michigan
So last week I made a post about how I replaced my cylinder head after letting the car sit for probably 3 months. All new timing components as well. Well after finally getting everything together it only runs on cylinders 1 and 2 and I'm not sure why. You can pull plug wires 3, and 4 with zero difference while it's running. I made sure my injector clips were tight, switched my injectors around. There is even compression across the board, presumably fuel, and plug wires seem to work fine. I know my CAS isn't set exactly right, but it couldn't be off by so much that it only runs on 2 cylinders, right? Any suggestions would be helpful.
