JackStieben
- 200
- 21
- Feb 11, 2014
San Antonio,
Texas
Hello, I'm running an E316g with Evo9 injectors stock motor. I noticed that the turbo was taking longer to spool up and I was hearing a strange noise that sounded like plastic hitting repeatedly under light load. My boost leak tester did not want to pressurize past 5lbs and the only leaks found were from a TB gasket and my dip stick. It was blowing a lot of air from the dipstick. The turbo has some sorta bad side to side but no in and out play. Is it time to rebuild my turbo? Any input is as always, greatly appreciated.
