Talon96fwd
- 311
- 33
- Apr 11, 2011
Alexandria,
Virginia
I can't believe you decided to part the car out. Feels like you just finished it and have now begin to enjoy the car.
What's the new turbo set up
Thank you!^All the best to you mate!
The original valve cover I ran that I modified in this thread did have the baffles put back in. I drilled and tapped it.Nice the new valve cover and fittings look good. Did you put the baffle back in? I'm thinking of leaving mine out.
He drilled and tapped the valve cover to put the baffles back in.
Going back through the thread I saw those bumper quick releases. From where they are in the bumper it looks like you made brackets for them?
I was gonna throw a baffle back in mine. The guy that did the welding for me burnt it up pretty good so I'm gonna cut it out and probably leave it out. I also have -10 lines welded in the stock location. Keep posted on how fast the catch can fills up. I knew you'd keep those wheels they look great!Decided to have a dedicated wheel/tire setup for the street.
16" Rota Grids with Nitto 555 tires. Fitment is perfect!
Here's the new valve cover I mentioned.
Exhaust manifold is on its way! I ended up going with a JM Fabrications T4 divided top mount.
They are a 245/50/16What size tires are those nitto 555's?? They look great.
I sure will!The manifold looks great. JMFab is one of my favorite DSM venders. They make amazing stuff. Let us know what you think about the S90 when you get it in!
I agree they look great. I may change the color but i'll leave them for now.Love the tire wheel combo!!!
I checked and verified they are 16x7 Grids with a +40mm offset. I'll have to measure the tire width as i'm not sure.What offset are the grids? are they 16x7? I've been wanting to get on a 24/45/16. How wide do the tires measure?
On the intake/S90, what are you thinking about doing with the 60mm inlet to the intake. I don't think it's possible to port it to 70, unless there is a massive taper on the inlet. I was going to do a 65mm ford one on mine but decided against it because of that.
