boostdawd
Supporting Member
- 1,430
- 320
- Apr 6, 2010
phoenix,
Arizona
Thanks for the clarification. I had no idea. Never really seen that on my head. Been like this for a few years with no issues or leaks.
I just looked back at the invoice and you are correct, I purchased the rx boost controller by accident, it's only good for an additional 5 psiThere are two different hallman pro boost controllers. One being the pro version that allows you to run a lot of boost over the waste gate, and the pro rx version that only allows you to run 4-5psi more than waste gate pressure. Seems like you have the pro rx version with the weaker spring in it.
