Galipso
Supporting Member
- 223
- 17
- Aug 23, 2011
Tampa,
Florida
So i've been dealing with this issue continuously over the last 2 years. Ive done lots of research on these forums and read a lot of discussions, none of which have helped me fix this issue permanently, only temporary. Here is what i've done:
Fidanza flywheel, 6 puck clutch disc and pressure plate by XTD
Any suggestions?
- Replaced clutch master cylinder
- Bled the clutch system
- measured clutch slave for travel
- backed out the upper adjuster for maximum clutch travel
- adjusted the rod to the pedal (over and over and over again)
Any suggestions?
