Christoph
- 81
- 11
- Jul 6, 2014
Miami,
Florida
Hello, I have been trying to read my ecu with ECUflash but I get a pop up error while doing so.
I have a 1999 Eclipse GSX with a verified flashable 99 black box ecu.
I have installed ECUflash and Ceddymods correctly.
I have the HEX and XML files in the correct folder.
My vehicle selected is the 99/evo5-6; which I believe is correct.
The key is in the correct position.
The reflash connector is in and has continuity with pin 79.
ECUflash acknowledges that I am connected to the ECU.
I have read all the threads on this website regarding failure to read ECU's. They do not pertain to my situation and non of them describe a log anything like mine.
Here is the log:
[16:55:10.381] using metadata XML ID read_evo65 from file C:/Program Files/OpenECU/EcuFlash/rommetadata/read templates/read_evo65.xml
[16:55:10.396] J2534 API Version: 04.04
[16:55:10.396] J2534 DLL Version: 1.01.4671 Mar 11 2016 19:11:49
[16:55:10.396] Device Firmware Version: 1.16.4647
[16:55:10.396] Device Serial Number: TAQVz8Yq
[16:55:12.068] sending init sequence 2
[16:55:14.130] interface close
I would really appreciate some help here.
Here is the log:
