Karmah
- 109
- 1
- Feb 10, 2015
Hazel Park,
Michigan
Been having this TPS Circuit Malfunction code forever out of nowhere, car still runs fine, but I'm sure I'm losing out on some power. I checked the ecu, someone had soldered the wire some time before, but it had broken. Fixed it correctly, checked pin terminal in connector, was all good. Still no TPS volts or %, how can I diagnose what is wrong and causing this? I have tried 3 good TPS and no luck. Anyone have any advice on how to diagnose this issue?
