The most difficult, random question ever asked.
No, because the first thing you should do on every DSM is cut that garbage off and loop the wires.
What issues?
It ain't so.
I've done this on dozens of 1G DSMs. I think this is around step 2 of fixing shit the factory did wrong...I typically do this right after I unplug the clutch switch.
Well the non working a/c was one of the first thing I removed when I bought the car back in 2006, along with the condenser fan. Now I'm all old and shit and want comfort back so I just reinstalled complete a/c from scratch with all new parts ( minus lines ) and im running twin 12" Spals. So needless to say I never had to wire a second fan until now. Thanks for the info.
Well. after driving with the a/c on for a day I found the 20amp condenser fan has blown. I installed a 30 for now. These fans are rated at roughly 10amp continuous but perhaps they spike over 20amps during startup. Any thoughts?
Keep the 20amp in, i learned its never wise to change the fuse ratings. There's no way a start up would double the amperage. If a fuse is blowing out, 99% of the time it's either wired wrong or you have a short to ground.
How many amps is that SPAL fan rated to pull?
I'm going to take a multimeter to it tomorrow, I'm having other issues as well. the car drives like shit with A/C on and it doesn't like to idle with the load of the compressor.
