bodhi_boyd
- 0
- Jul 19, 2016
Olathe,
Kansas
Hey folks, I'm pretty new to the community, and cars in general so go easy on me if im not as savvy as some of you
A while back the motor in eclipse gst messed up bad and i had to have it machined. I dont know what all the machine shop did to it as i didnt know jack shit about cars at the time.
but, its been reassembled by myself so i like to think i know damn near every nook and cranny of that engine now.
now here's my problem, the car will start and "run" but it runs like crap. the rpm needle stays at zero while idling and it massively resists me trying to accelerate it (limping it home from truck after a move). when i put it in first it feels like i shoved it in third, in terms of resistance to acceleration.
it has brand new coil packs, spark plugs, and plug wires so those arent and issue.
tested and replaced the maf thinking that a messed up one was throwing off my a/f ratio. though that didnt help and i most likely didnt perform the test correctly. again im pretty new to all this.
I didnt do the timing while the motor was out of the car and still dont really know how so that may be an issue
cleaned the map sensor and nothing changed
obd scanner throws code for a misfire
any help would be greatly appreciated and let me know if there is any detail you would like me to answer, ill try to the best of my abilities.
thank you for any of your time
