KilleRabbit
- 36
- 9
- Jul 3, 2016
Deltona,
Florida
Hello,
I just purchased my first DSM a few days ago. I picked up a 1998 Eclipse Spyder GST with 130k miles for $1800. The car is bone stock except for the front fenders (they are Z3 look alike fenders) and a paint job.
So here is the deal with the car, take it as you will.
Upon first impression the car looked great, body is in fantastic shape. The only aesthetic problem with the exterior is that the rear window needs to be re-adhered as it is only still adhered across the top and is just hanging there.
The interior has the usual wear and tear that would be expected from an eight year old car.
Now down to the nitty gritty of the engine:
Upon startup the car ran/runs fine. After driving it the first time when I tested it I noticed that when I came to a stop it would blow blue-ish white smoke from the exhaust. My first though was the turbo was burning oil. No big deal, I plan on upgrading that anyway. When I went back and purchased the car and began the trek home it was blowing more smoke than it had previously, but after I got going it slowed to almost being non existent. Mind you the engine temprature stayed perfect the entire drive and it has not overheated at all. So I jumped around on forums looking for other possibilities (mind you there is no coolant in the oil or oil in the coolant) and found that it could also be an exhaust valve seal.
I did some testing yesterday to double check to see what else may come up as it is not and has not thrown any codes at all.
Compression test results were much better than I expected with 185, 175, 175, and 180 psi in the cylinders.
Then I did a block test to check for exhaust gasses in the coolant system:
It took a while, but the oil turned yellow confirming the presence of exhaust gases in the coolant system.
Alas I ordered:
Head Gasket and all the hardware, seals, and gaskets from there up
Timing Kit
Oil Pump and gaskets associated with it
Clutch master and slave cylinders (I have some friends who have had issues with these components on these cars in the past so better safe than sorry)
I also ordered some gauges and pods and a CXRacing radiator kit
Im going to start tearing down the engine soon and probably have the head cleaned and tested if my buddy can get me a deal at his shop.
Parts will be coming in slowly over the next week or so.
I figure a minimal overhaul will keep me on the road longer and avoid some issues that could come up in the near future.
Any input you guys have or any questions that you may want answered about anything feel free and I will do my best to accommodate and graciously welcome all input on anything related to the work I have in front of me over the next week or so.
Thanks guys!
Alas I ordered:
Timing Kit
Thanks guys!
