Matthew Lipford
- 32
- 0
- Jun 22, 2016
Canton,
Michigan
So my car died the other day and I found some loose wires to the pigtail 4 pin harness that plugs into the alternator. I have checked the 100 amp fuse many times and have battery voltage across it. If my battery light is not coming on at all can this still be a bad alternator? I have fixed all the wires on the pigtail and the output voltage running is from 2-10 volts on the alternator. So for some reason, maybe voltage regulator or ecu? Will a bad alternator cause the battery light to stay off ? Thanks
