Evo 3 Intake Speed Density Tap
Carney714
101
Jun 4, 2012
Santa Ana, California
Hi guys
Just got a Evo 3 intake manifold and I will be installing within the week. Problem is i have speed density and dont know the best place to tap into the intake. Any pictures with your Evo 3 / SD setup would be helpful! Thanks
Picture is what i currently have
I was thinking about one of the runners since it has the most material, just wasnt sure if that was a good source. Heard towards the top to avoid any type of moisture getting in the sensor.
How about this spot? I can drill and tap into it.
I bought a fitting from McMaster that was straight threw for the brake & a side tap for my AEM MAP & threaded it I between the the brake booster nipple. No drilling a only took about 5 minutes to install.
Got this setup, Wanted to hide the SD a bit. But thank you for your help! I think im going to paint the fittings black just to disguise it.
