jakk220
- 1,319
- 312
- Nov 13, 2010
Akron,
Ohio
So I just got my girlfriends 1G running and the 16g turbo on it is definitely blown. The car puts out blue smoke and there was oil inside the housing when I pulled the intake off (there is no catch can or anything recirculating to the intake so its more than likely from the turbo) however the turbo makes a whining sound under boost.
My question is what usually causes the whining sound? I'm thinking about just rebuilding it yet I want to know if a basic rebuild kit such as this one http://turbolabofamerica.com/mhi-14b-16g-20g-turbo-rebuild-kit/ will work to fix it since there is no shaft play and the turbine wheel seems to be okay. Thanks.
