Kapok6
- 1,392
- 267
- Aug 10, 2004
Fort Worth,
Texas
It appears that the 6 bolt oil strainer is no longer available. Part # MD113024. So what are you 6 bolt guys doing? Are the 1G 7 bolt strainers a compatible replacement, and if not, how are you cleaning the 6 bolt strainers out? The the actual tube protruding into the bowl part of the strainer, it makes it impossible to to just spray carb cleaner through the strainer and wash everything out of the other end of the tube since all the metal shavings and whatever other cruddy particles there may be are just going to get trapped at the base of the tube and not be able to actually make it into the tube itself.
