Can you rebuild awd trans with fwd trans?
Barney Dsm
42
May 25, 2016
Westland, Michigan
I have two Ted turbo transmissions and was wondering if I can rebuild a awd transmission with a fwd
get a copy of caps or asa and make comparisons. no shafts or gears interchange. only thing left would be hub sleeves and synchros. some of those might but those are usually the parts that need replacing. so answer is still no.
The stealth twin turbo transmission is a getrag unit and is totally different.
What year FWD and AWD transmissions are you using? what are the model numbers on them? there are parts that are interchangeable but I need to know exactly which transmissions we are working with. I have experience with all of the fwd and AWD transmissions as well as the getrag transmissions.
On the bell housing. Probably starts with WMxxxx...
How big of a difference is 3mm height on the pressure plate the fork is moving full actuation but no clutch disengagement
