1G passenger Hid won't turn on
Jayy
Jul 15, 2015
Phoenix, Arizona
My old his recently went out and I went to a local shop to two new bulbs and they only have the whole new kit
I replaced the kit and put everything how it was before and the passenger side doesn't want to turn on it never has since I've owned the car and now it has new wiring harness new bulbs and ballasts and the passenger side still won't turn on I'm wondering if where the hids plug into the stock harness if the red and blue wires are reversed( I just put. Them where they originally where) I'm not to sure though
When installing the HID kit, be sure you have the plugs in the ballast the correct way. I know I had to flip mine around and they worked. What kit did you buy? Brand?
I'm not sure I paid 100$ at a local tire shop the car already had them and the passenger didn't work then but the bulb was blown I went to buy two bul s and ended up buying a kit h4 bulbs hi/low and the passenger side still doesn't work doesn't even flitter
Are you getting power to your fuse? Power to the headlight connector before the ballast? I would test that to see if it is a bad ballast or if you have your wiring wrong.
Yes I'm getting power to the fuse rhe wiring is right I'm going to try a new ground I Switch Ballast FROM Driver to PASSENGER side and it still didn't work
sounds like a busted lowest bidder manufactured product. 100 dollar hid kits are a dime a dozen and cost the same. the retailer then marks it up 300%.
the godspeed turbos of the lighting world.
relay, ballast, ignitor, pick any or all.
these kits are on chinese dropshipper sites for 30 bucks or less.. could always replace it.
Is this correct LOL
I agree with the ground being the issue, I had the same problem with my car, I hooked up the hid kit and it worked fine then 2 minutes later only one light worked. I tryed Everthing even went back to the stock setup, only to find I had a broken ground wire. As soon as I fixed it everything was fine.
