dyablo
- 250
- 2
- Jan 22, 2005
Indio,
California
got an auto 99gsx that sat for 7years with a blown engine. Got that replaced when went for a drive, noticed the brakes worked but I guess not with full clamping force. Figured it needed new pads and resurfaced rotors. did that on all four corners.
problem still happening so I went and bleed the whole system. tried again still not stopping very well figured maybe a bad master so I replaced that. bench bleed it and rebleed the brakes still having the issue.
thing is at say highway speed I can slam the brakes and they work just fine ABS kicks in. I noticed the issue is at very low speeds like below 20mph I can slam the brakes and they start to work but I run out of pedal travel.
only thing I can think of is a bad booster but at almost 90$ a piece id like to narrow down my options.
