shadowdrag
- 191
- 0
- Oct 17, 2005
Beaverton,
Oregon
OK, I'm out of ideas. My car sounds like a Subaru WRX, it will not go anywhere. It will start up and idle, but if you drive it. It will stutter, back fire and die. I did all the research I can, and got nothing. I replace Power Trans and coil pack with used ebay dsm parts and still nothing. Cylinder 4 and 2 plugs pulled during idling and no sparks, pull 3 and 1 and engine lowers down.
Both coils were tested.
Coil 1: (mine) = primary= 0.000 Ohms and secondary = 12.5 and 12.6 kOhms
Coil 2: (ebay) = primary= 0.000 Ohms and secondary = 12.9 and 13.0 kOhms
Both power trans are working good during 1.5 volt test.
The manuals just state that if the reading are not within the specified value, replace the ignition coil, but the manual does not say if both values differ, replace..
So it does seems that I am within specs, I'm I right.
Thanks for any inputs.
