Mike_GST
- 90
- 8
- Jan 5, 2016
Brazil,
South_America
Hello guys.
I looked around for threads like this, but none of them presents irregular working like mine.
I have now my '98 GST for one year and half and something is bothering me since ever.
My car sometimes pulls strong and sometimes not. No reason I can notice.
Same day, same temperature, same time, same conditions. I pull once, the acceleration presses my body to the sit. Then stop the car and pull again. The rpms goes up, the pressure gauge shows full boost, but the car has a very weak performance. In this same exactly pull, if I release and quick the accelerator, the car reacts full performance again! Pretty wird thing.
Everything in the car is stock. When I bought it, replace all the belts, spark plugs and fluids.
At first I was suspicious about the wastegate, that an erratic opening and closing could be doing that.
The car has VERY LOW MILEAGE, so being sitting could make some moving parts get sticky, I thought
Then I released that little rod that connects it to the actuador and moved with my hand right and left.
Very smooth movement! Is not the wastegate.
Well, I don't believe this problem is related to the air flow, neather from or to the engine. It couldn't be such a leackage on the lines, way to make the performance drop that much, without been noticeable in the gauge, which by the way, shows full boost.
Do you guys have any guess?
Thank you very much.
