1000hp turbo?
TheFlashDSM
Supporting Member
1,082
311
Feb 18, 2010
stony brook, New_York
okay i cant really find a stright answer so ill ask you fellow peps LOL
im currently doing a 1000hp build on my 99 auto gsx i know, i know, im not buying everything new just some things,
main question what turbo should i run to reach my goal of 1000hp, i know somewhat about sizes and such but i need advice from 800+ car builders. and P.S. im doing all this in my garage by my self so any help would be much appreciated!
I'm not trying to be a douche.....but if you have to ask that question then it's probably not a goal you should be currently trying to obtain. Regardless, FP Super 99 off the top of my head.
I'm trying to be a douche.....but if you have to ask that question then it's probably not a goal you should be currently trying to obtain. Regardless, FP Super 99 off the top of my head.
i have done a lot of research and its hard to find straight answers but thanks, and yea im doing this check it out, http://www.dsmtuners.com/threads/my-2g-dsm-second-build-this-ones-going-smoother.499369/ and ill be using Howard I beam 7 Bolt rods which i already have, then wiseco hd pistons, acl race main and rod bearings, cnc magnus built head, Manley crank and ill be working with a machine shop to do all the calibrations and measuring on all the parts trust me i did my work just need a little push on the turbo!!
super99, GT42, HX52, S372 Some sort of a 76mm pte. I'd be looking at the guys who are making 1000whp and see what they are running.
Jontsi, twicks69, littlerazcal, boostin performance, all have 1000whp dyno sheets floating around. Maybe check what they had.
exactly the answer i needed thanks so much for the help, now gonna do my research on them and see what fits my needs better
GT4202 will do it.
I'm really close, but no 4 digit sheet... Yet.
