9 T GSX
- 169
- 18
- Jan 19, 2008
St.Pete,
Florida
I'm in the process of freshening up some of my harness and my first area I'm going to do is the injector wires and new connectors I have all the loom and tape off, all that's left to do is run the new wires, solder etc. However when I got to the resistor pack female plug I ran into my issue. I have a set of assorted tiny screwdrivers that should allow me to depin this connector however no matter what I tried the pins are not coming out. I've tried putting the screwdriver into all the usual holes that release the pins but nothing works. Just seems there are no release tabs or place on the pin to either depress or lift up on to release them.
Has anyone removed these before if so what is the trick??
