95 talon tsi awd how about you
Here's my set up...
..Bake and Blastengine block Clean all parts for assembly
Wiseco HD 2 7-bolt 8.5:1
Oliver Billet steel 150mm rods
7-bolt H Rod Bearing
7-bolt H Main bearing set
Bore & Hone cylinder
Polish Crankshaft
Balance I4Balance rotating assembly for Inline 4 engine
Hang Pistons Flo...Hang
BlockDeck Inline engine Clean engine blockFreeze plugs
Balance shaft bearings
ARP 7-bolt main stud set
Align Hone engine block Assemble
4G63 short block Force Engineering ZFG Short Block
Machine rod Machine oil squirter in connecting rod set
Kiggley Street Beehive springs& retaineretainer set
3 angle valve job
Force Engineering 4G63 port work (Stage 1)
Deck Cylinder HeadLevel and cut cylinder head
Assemble DOHC head
Supertech 1mm over Intake valve
Valve stem seal set
Bead blast & hot tank cylinder head
Exhaust stud set
Supertech Exhaust Valve Standard size
Kiggly HLA
Street&Strip 4g63 head (stage1)
Stubby Shaft
Castle plug
Balance shaft spacer
Tensioner Pulley
Idler pulley
92 94Tensioner
Strait cut oil pump gears
Force ISF oil pump gear finish water pump
timing belt
3 gen lifter set
Labor to complete long block assembly from short block
APR custom aged 625+ 7-bolt head stud set
4G63 gasket kit
Fel-Pro Perma Torque HG
Mail oil galley plug
7-bolt core short block
7-bolt core cylinder head
ATI balancer
Fidanza adjustable cam gears
Gate's Kevlar timing belt
Kelford 272 cams
FP ported GREEN turbo
FP ported exhaust manifold
Punishment racing 02 housing with external tial waste gate
Megan 3" exhaust
I hope i didn't forget anything LOL
Just thought id Mencken i ordered a few parts from extreme psi this week.
With any luck I'll have the new parts by Monday...
I'll take pictures and post them here Tuesday.
Here's the goodies....
Tial 50mm blow off valve.
MAGNUS fuel rail.
Walbro 450lph fuel pump.
Aeromotive A1000 13101 fuel pressure regular.
Aeromotive fuel pressure gauge 0-100 psi
Innovate motorsports MTX-L wide band.
Zaklee corp clear cam gear cover
ECM Link V-3 with boost control solenoid.
Mishimoto racing thermostat
Fuel Injector Clinic 1650cc high-Z
Fuelab 828 series in-line fuel filter 8AN inlet/ outlet 10 micron filter and 40 micron i got both filters
Hallman pro boost cotroller kit
I finally found a good place to put the Aeromotive 13101 FPR.
The 8an fuel filter from fuelab didn't fit in the stock location. so im going to weld up a pice onto the stock bracket on Wednesday.
Love all the parts pics - looks like Xmas morning. Thanks for including us in the build. Keep up the good work!
Heres what i did for the fuel filter bracket to fit where the stock one sat.
I cut the stock bracket with a grinder and put washers in place to space it away from the break lines. then got longer bolts from jerry's. Also used scrap steel from coyote steel.
Cost less than $10.
I'll Post agine next week to show how it looks on the car and probably paint it.
cleaned wheel wells a while ago. Found rust and rubber LOL. So i sanded it down and rattle can painted it.
Rust is car cancer LOL so it had to be dune at some point.
Fuel filter in stock location for under $10.
I recommend this to anyone before putting it under the car.
Looks great and should stay clean.
Now i need a clutch fast like yesterday.
I wanted to use the south bend ss-x Kevlar/ceramic Clutch. But i didn't see overnight or next day shipping on the tmz website.
Anyone know where i can get this clutch kit fast?
new valve cover shaved 10AN fittings welded and sonic cleaned. Pluss its not cracked like the old one LOL and it's the some color as the block, fuel filter, blow off valve and waste gate.
