spyderdrifter
- 5,267
- 711
- Jul 11, 2009
Somewhere in,
Colorado
I have a parasitic draw that I've narrowed down to the room light fuse circuit. Yes I've read through those threads and I've checked the fuses and a few relays under the dash on the driver side. I know I need to find out how much current is being drawn while my car is off, and I'm not too sure how to hook up my dvom for milliamps and YouTube so far hasn't been clear. How can I do this? Also, nothing I pulled from under the dash (driver side) turned off my test light. The light does go out when I pull the cradle that houses the room light and radio fuses, but only when the room light fuse specifically is removed. What else can I check? I know there's a lot under the dash to check, and haven't done it all.
