99gst_racer
Moderator
- 11,981
- 1,553
- Apr 5, 2003
Coloma,
Michigan
10% is a good discount for this kind of purchase. That's something to be thankful for. That's $527 off of a 210DX or $680 off of a 280DX. Not too shabby.
I assumed the same thing, but I haven't seen anyone discounting the 200's like that. My guess is that it's such a good seller that nobody needs to discount them much (if any) to get rid of them.If the 200 is getting discontinued for yhe 210 people will be discounting the 200's to get them out of their stock, I'll be looking at that time probably. I'm so sick of how basic my diversion 180 is.
I'm actually looking at the complete kit too, so it's a couple grand more than the box itself. Miller part number 951668 is what I'm after. Best price I've found so far is about $5270.10% is something to be thankful for but its not 30-40%. I could check into it but you still have taxes and shipping to add back in. That would probably bring the total close to what you could get it for.
EDIT: Just called the local welding supply out of curiosity and the 210 DX is 3,386. Thats about the same price as cyber weld.
As for the 210 DX VS 200 DX price, they are about the same right now. Cyber weld actual has the 200 priced a few dollars higher than the 210. The local welding supply has the 200 slightly cheaper. All that may change but I am no salesman.
That was punny *da dum chh*Thats looking amazing there Kyle! Weld done haha (did you get my pun)
Thanks for the advise. I will use that and probably go up a cup size for sure. This was on a 7 that came with the machine.Clean the material with acetone before you weld. For stainless use lots of argon, depending on cup size you could go up to 30cfh with a 12 or 14 cup
220v. It's an inverter based machine so I can't use pure green.Scott, what power supply? Thoriated (red) tungsten isn't really the best for aluminum really ever.
