turtlebain
- 447
- 27
- May 16, 2012
Rochester,
New_York
Wired AEM 5-Bar MAP sensor and GM IAT into the stock harness about a week ago. I had some issues to take care of in the fuse box region. And just today got to get into link and select these sensors in the ECU.
Problem is, the IAT is reading -40 deg. F and the MAP is reading -13 in. Mercury. The MAP appears to be fluctuating slightly but the temp seems to be pegged right there, what could cause this to be happening?
Is there a switch (check box) in link to "enable SD operation?" What did I miss?
