farmer890
- 123
- 29
- Apr 26, 2014
A,
AB_Canada
Trying to install a brand new oem oil pan on a perfectly clean and prepped 7 bolt 4G63 on a stand. Did a test fit with the pan, seems the girdle is touching the inside of the pan juuuuust enough to make all the bolt holes not line up. I'll have to bore out all the bolt holes in the pan to make it work. Has anyone run into this before?Second question, I have a set of oil pan bolts from STM. I have read that 2 of the bolts that go near the timing belt are shorter than the rest, however all 19 bolts are the same length in this kit.
One bolt sticks through by the oil pump sprocket. Is this going to be an issue? It looks out of the way enough for the timing belt to clear but just wanted some second opinions.
